2001 Pontiac Grand Am Ignition Cylinder
2001 PONTIAC GRAND AM
156,000 MILES • 4 CYL • FWD • AUTOMATIC
JERBREMSER
I have a 01 Grand Am and i just went through repairing quite a bit under the hood, alternator, water pump, thermostat, oil pan gasket, and a coolant flush. I then started the car let it run for a while and eveything seem to be ok. There were no more leaks and the temperature was staying normal. So i took the car out for a nice drive. The car started and turned off a few times through out the day. When i got home that night i then needed to go back out and when i went to the car to start it the key would not turn in the ignition cylinder. The steering wheel moves freely from all the way to the right and all the way over to the left. The steering wheel is NOT LOCKED making the key work this way. I have the ignition cylinder taken apart now getting ready to replace it with one that has a key already coded so i will be making my car a 2 key system which is fine with me. My problem is that i can not get the cylinder out because i can not turn the key and pull. I read that there is a rod inside the housing of the cylinder which is locked and this rod needs to be drilled out. Is this correct? All i see is the plastic housing. Where do i drill if that is what i need to do? Can you provide a picture or diagram of where this spot may be? Or can you let me know if there is another way to do this.
Jul 1, 2010 at 3:18 AM
RICHZOMBIE
  • 173 POSTS
Before you start drilling or anything, try checking the shifter. Sometime the button you push to switch gears doesn't come all the way out. You can also check the linkage to make sure the vehicle is locked into park all the way. If you still need to change it then there is a panel under the steering column that you can remove and there is a pin there to get the key out when it gets stuck.
Jul 1, 2010 at 3:53 AM
JERBREMSER
I will give the shifter a try. My issue though is not that my key is stuck in the ignition. I can get the key in and out i am just unable to turn the ignition. Almost as though the tumblers are not all set anymore to my key so they dont want it to turn. Im not positive that its the tumblers but just an idea.
Jul 1, 2010 at 4:00 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
Since the lock cylinder is not rotatable, follow the link below and it will provide you with details and pictures on how to go about this repair..
http://www.ondemand5.com/mric/common/asp/AnnotationAttachment.aspx?FileId=1771
Jul 1, 2010 at 2:16 PM
2 LINSEY
  • 287 POSTS
Thank you for using 2CarPros.com. We appreciate your donation and look forward to helping you in the future.
Jul 19, 2010 at 5:53 AM
