2001 Pontiac Grand Am GASOLINE SMELL WHEN USING HEATER
125,000 MILES • 6 CYL • 2WD • AUTOMATIC
WENDYIRIS13
Everytime I use the heater in my car, I get an overwhelming smell of gasoline in the interior which is causing severe headaches. What could be causing this??
Dec 6, 2009 at 1:45 AM
MMPRINCE4000
  • 8,548 POSTS
There would have to be a leak in fuel system, or a problem in the EVAP system.
Start by checking the fuel system underhood. Look at all fuel connections, fuel injector connections, fuel rail and fuel pressure regulator.
Is your check engine light on?
Dec 6, 2009 at 11:48 PM
