2001 Pontiac Grand Am Dome light problem
68,000 MILES • 6 CYL • FWD • AUTOMATIC
MEH
What causes the dome light to illuminate when you apply the brakes and the car is almost stopped?
Dec 16, 2007 at 9:29 AM
BMRFIXIT
  • 19,053 POSTS
[quote:5b48c06d8b="meh"]Electrical problem
2001 Pontiac Grand Am 6 cyl Front Wheel Drive Automatic 68000 miles
What causes the dome light to illuminate when you apply the brakes and the car is almost stopped?[/quote:5b48c06d8b]
check your door and other doors if any open or the door switch maybe at fault
you can check with the scanner which is open by scanning the BCM
Dec 16, 2007 at 12:47 PM
MIKE H R
  • 3,094 POSTS
Check by the brake pedal to make sure there are no wires rubbing when you depress the pedal.
Sep 22, 2016 at 12:06 PM
