Camshaft Position Sensor
194,000 MILES • 6 CYL • FWD • AUTOMATIC
CHARLOTTE830
How do I change the cam shaft sensor?
Jan 23, 2009 at 1:43 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Locate sensor at front of engine (pictured below). Usually there is an electrical connecter and a few bolts that hold it in place. Simply disconnect and remove for replacement.
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_65.jpg
Thanks for using 2CarPros.com!
Jan 23, 2009 at 1:59 PM
ADODSR
camshaft sensor location and installation
Jun 14, 2021 at 3:33 AM (Merged)
  • 75,988 POSTS
REMOVE OR DISCONNECT
Disconnect the negative battery cable.
Remove the serpentine drive belt.
Remove power steering pump assembly.
Remove the electrical connector.
Remove the bolt.
Remove the sensor.
