2001 Pontiac Grand Am blinkers/flashers
134,000 MILES • 6 CYL • 2WD • AUTOMATIC
PMPETRIE
Car would not start, so shop replaced the ignition, every since then turn signals work intermitently and the the 4-way flashers click at rapid rate. Pushing the 4-way switch will stop the clicking and the turn signals work temporarily, then you have to do it all over again. The problem is dangerous, annoying, and increasing in frequency. PLEASE HELP!
Mar 20, 2009 at 10:23 AM
LOWCOST67
  • 35 POSTS
i have seen this a few times. you need to replace turn signal switch. wich is also the lights,wipers,ect its all one unit
Mar 23, 2009 at 9:55 AM
