2001 Pontiac Grand AM 2.4
FISHHUNTER
I am having trouble with my transmission shifting extremely hard. The service enginge soon light is on as well as the TRAC light. I had a mechanic test it and the following is the error codes and messages it displayed. Can anyone give me a idea of what may be wrong? Any help appreciated
ABS Code
C 1254 Abnormal shutdown detected
C 1275 PCM requested ETS to be disabled
PCM Code
U 1000 or V 1000 Class 2 serial comm. problem
Apr 18, 2007 at 7:29 AM
SERVICE WRITER
  • 9,123 POSTS
IS your battery fully charged? has it been disconnected? Either case will set the c1254, the other two are probably due to this code. You need to have the codes cleared with a scanner, If they comback, then it is probaly a wiring problem or a problem the the ebcm
Apr 18, 2007 at 7:48 AM
FISHHUNTER
[quote:154d8d7a2e="Service Writer"]IS your battery fully charged? has it been disconnected? Either case will set the c1254, the other two are probably due to this code. You need to have the codes cleared with a scanner, If they comback, then it is probaly a wiring problem or a problem the the ebcm[/quote:154d8d7a2e]
Battery was fully charged. It happened while I was driving it. I recently had the brakes and rotors replaced. I am not sure if that would cause the issue or not.
Apr 18, 2007 at 7:58 AM
SERVICE WRITER
  • 9,123 POSTS
Have the codes cleared, if it comes back, some further testing with the ebcm will be needed.
Apr 18, 2007 at 8:20 AM
FISHHUNTER
[quote:bc40b666ba="Service Writer"]Have the codes cleared, if it comes back, some further testing with the ebcm will be needed.[/quote:bc40b666ba]
The codes have not gone away. We did not try clearing them and running it again though. As hard as it is changing gears I am afraid it may ust the joints or break the motor mounts.
Apr 18, 2007 at 8:26 AM
SERVICE WRITER
  • 9,123 POSTS
Not sure what to tell you other than what I just said, that you didn't do.
We could talk hockey :)
Apr 18, 2007 at 8:36 AM
FISHHUNTER
[quote:024ec9592d="Service Writer"]Not sure what to tell you other than what I just said, that you didn't do.
We could talk hockey :)[/quote:024ec9592d]
THanks for the input anyway.
Apr 18, 2007 at 8:52 AM
