2001 Pontiac Grand Am
WARREN WAGNER
  • 2001 PONTIAC GRAND AM
  • 6 CYL
  • 74,000 MILES
Engine temperature low heater blows cooler air
Monday, December 24th, 2007 AT 9:21 AM
MERLIN2021
  • 17,250 POSTS
Let the engine cool off, then drain it down about a gallon, there is a draicok on the bottom of the radiator, then follow the upper radiator hose to the engine, there you will find the thermostat at the end of the hose, unbolt the two bolts. Leave the hose attached to the housing. Scrape old gasket from both mating surfaces, install new thermostat, spring towards the engine. Install the gasket, snug the housing bolts! Not to tight and bring the housing down evenly. Refill the coolant and that's it!
Monday, December 24th, 2007 AT 9:23 AM
