2000 Pontiac Grand Am Vibrating and noise while turning
2000 PONTIAC GRAND AM
127,000 MILES • 4 CYL • FWD • AUTOMATIC
LAPOZ825
I had just left my house and was turning in the store and my car started to vibrate and make a funny noise. It was really bad when I turned the wheel. My first thought was that it had something to do with the wheels like the axle or bearings then I talked to some people and they said it might have something to do with the power steering.
I was afraid to drive it so it sat for a day and I started it the next day and it was fine. I did add a little PS fluid too.
Any ideas where the vibration could have came from? Should I be worried about it anymore since its fine now?
Thanks and I appreciate any help!
Dec 1, 2009 at 12:19 PM
MMPRINCE4000
  • 8,548 POSTS
Raise car, put on stands. Grasp tire and push/pull both horizontally and vertically, if any movement then possible wheel bearing, ball joint, tie rod, control arm bushing.
Check CV boots for any signs of leakage or cuts/rips in rubber boot.
Also check PS pressure and return lines for leaks.
Dec 3, 2009 at 12:05 AM
