2000 Pontiac Grand Am THROTTLE
2000 PONTIAC GRAND AM
HUNTER9
Engine Mechanical problem
2000 Pontiac Grand Am 6 cyl Two Wheel Drive Automatic
THROTTLE STICKS IDLES HIGH .I REPLACED THE THROTTLE POSITION SENSOR BUT IT STILL STICKS .DO YOU THINK THAT IT CAN BE THE CABLES.
Nov 21, 2009 at 10:38 AM
MERLIN2021
  • 17,250 POSTS
can be, or a worn shaft on the throttle plate, remove the cable, operate it by hand, does it return normally? Idle OK? then replace cable.
Nov 21, 2009 at 11:30 AM
HUNTER9
THANK YOU IT WAS THE CABLE
Nov 23, 2009 at 5:52 AM
MERLIN2021
  • 17,250 POSTS
Welcome!
Nov 24, 2009 at 2:24 AM
