2000 Pontiac Grand Am running hot
REGINA21
  • 2000 PONTIAC GRAND AM
  • 6 CYL
  • 4WD
  • 150,000 MILES
My car is still running hot, eventhough I got a new thermostat put in and fan don't work unless air conditioner on.I had some seal stuff put in for the head gasket also
Tuesday, March 17th, 2009 AT 5:24 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Hi Regina,
The fan that is coming on only when the A/C is on is the Condensor fan. There should be a second fan that comes on when the engine reaches a certain temp.
Is engine light on? If so have codes pulled at your local auto parts store.
Check the relays located in the under hood fuse box.
Tuesday, March 17th, 2009 AT 5:35 PM
