2000 Pontiac Grand Am power loss
FROGGER1
  • 2000 PONTIAC GRAND AM
  • 4 CYL
  • FWD
  • 31,500 MILES
It started when it had a weak battery, installed new batt. Starts good runs good loss of power at about 2000 rpm, will bog down and start missing if you floor the gas pedal.
Thursday, September 9th, 2010 AT 4:26 PM
Lack of acceleration, chugging, hesitating, jerking, bogging, misfiring etc. Could be caused by one of the following below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Thursday, September 9th, 2010 AT 4:45 PM
