Hi I have 2000 Grand Am SE it has been hestitating after you stop at a stopsign/stoplight then once you hit the gas it runs smooth. No check enginge lights are coming on had it on the computer and their is a misfire in cyclinder 4 my husband has changed spark plugs fuel filter checked injectors they are working properly and ran sea foam through it and nothing was just wondering if their were any other options. It doesnt idle rough its just like i said once you put it in gear and let off the brake it hestitates and as soon as you press the geas pedal its fine ??? Thank you for any suggestions you may have
Aug 25, 2010 at 2:41 PM
