2000 Pontiac Grand Am Headlights won't work
140,000 MILES • 4 CYL • FWD • AUTOMATIC
EMMJAY
I brought my car in to have the headlight bulb replaced because they only worked on highbeams. They changed the bulbs and the headlights will only work when the car is in park, and they no longer work while with the highbeams. So I don't have head lights while driving.
The repair shop stated they couldn't fix the problem because GM doesn't allow them to access the Body Control Module.
Do you have an estimate of the charges to repair the BCM? Is the BCM the problem?
Oct 20, 2009 at 3:43 AM
MMPRINCE4000
  • 8,548 POSTS
Never heard that one.
If it was the BCM, they should be able to give you an error code (BCM codes start with a "B").
I would go to another garage.
Oct 21, 2009 at 2:23 AM
EMMJAY
and the plot thickens...
Last night I discovered the headlights WILL work if the dash board lights are illuminated. (meaning it is dark enough for it to happen)
Which is a good thing, I guess.
Is the BCM replacements expensive?
I love a good mystery..but not when it is at my expense.
Oct 21, 2009 at 2:41 AM
MMPRINCE4000
  • 8,548 POSTS
I am not sure why they mentioned the BCM, I see no "B" codes for the headlights in the library.
"B" codes are airbag system and other electrical components in car (heated seats, Security etc).
Have them scan the BCM for error codes.
Oct 22, 2009 at 3:10 AM
