2000 Pontiac Grand Am headlamp repair
2000 PONTIAC GRAND AM
145,000 MILES • 4 CYL • FWD • AUTOMATIC
DIGIT1973
how do i replace a headlamp on a 2000 pontic grand am se
Mar 27, 2009 at 11:07 AM
JAMES11
  • 14 POSTS
It depends on if your if your replacing the whole assembly or just the lamp itself. If your just replacing the lamp then all you have to do is remove the plastic splash guard and pull up the two metal securing pieces they look like a straight piece of metal with a place to pull at the top and then pull out the whole assembly and find the headlamp and turn it and pull adn then to install do the opposite of removal. hope i could have been of service to you. thanks
Mar 31, 2009 at 1:27 PM
