2000 Pontiac Grand Am bent trailing arm?
115,000 MILES • 4 CYL • 2WD • AUTOMATIC
DEBBIEJ13421
I am wondering if you could help me. I jacked my car up on what I thought was a cross member and it bent. I was told it might be a trailing arm. It is in the rear of the car. On the drivers side. There are two ..... what look like flat plate steel but they are curved, they go all the way from one side of the car to the othere alond the axle. I jack the car up on one to fix a brake line and it bent. Can you tell me what it is and should the whole thing be replaced?
Jan 8, 2008 at 8:57 AM
SERVICE WRITER
  • 9,123 POSTS
Replace the arm for sure. May have to get it through the dealer. IF it is too pricy, might be able to get one from the junk yard. I would call that a trailing arm.
Jan 8, 2008 at 9:38 AM
