2000 Pontiac Grand Am ABS Brakes
71,000 MILES • 6 CYL • FWD • AUTOMATIC
GUZLECKI
When applying the brakes it seems that the ABS system is engaged even when braking at slow speeds. The brakes pluse all the time when brake pressure is apllied. Why is this happening? Is there a problem with a wheel spped sensor? ABS computer?
Mar 23, 2009 at 11:16 AM
RAINZ
  • 12 POSTS
Going in blind here. Did you replace any front wheel parts lately like bearings, hub assembly or brakes?
Sounds to me like a wiring problem straight from the factory. The sensor, if wired correct will apply the ABS when certain pressure is applied at certain speeds which stop your brakes from locking up. If the ABS wiring harness is wired incorrect it could sending the computer a message to apply ABS all the time. However, if you did not replace any pars, i suggest it could be a sensor gone bad. This could be either in the front or back. Good Luck
Mar 26, 2009 at 1:25 AM
