When the problem occurs, have a helper crank it, while you visually check for spark at the plugs. If you have spark everywhere, use a gage and check fuel pressure.
You might also check for any applicable trouble codes. To check for codes, at the least, you need an obd2 code reader.
SPONSORED LINKS
Friday, May 14th, 2010 AT 1:58 PM
