2000 Pontiac Grand Am
KLINDEMA
  • 2000 PONTIAC GRAND AM
  • 6 CYL
  • 71,000 MILES
Car leaks orange fluid occasionally. Originally thought it was coolant, but coolant level seems fine. Heat will work for a few seconds, but doesn't stay warm. Engine temperature gauge went into the red for a split second, but then cooled down and stayed around 210ish.
Thursday, March 13th, 2008 AT 8:47 AM
RHALL77
  • 3,361 POSTS
Sounds like you do have a leak. Check and see if your water pump is leaking and check and see if your lower intake gasket is leaking. You may have to pressure test the cooling system to find the leak.
Wednesday, July 29th, 2020 AT 10:11 AM
