2000 Pontiac Grand Am
TERRY0712
  • 2000 PONTIAC GRAND AM
Air Conditioning problem
2000 Pontiac Grand Am 4 cyl Front Wheel Drive Automatic
my air conditioner is not cooling that much I bought a freon kit for walmart and according to it my freon is full, are those kit any good, what could be the problem
Tuesday, August 25th, 2009 AT 5:03 PM
MMPRINCE4000
  • 8,548 POSTS
When adding freon, the engine must be running and AC on max, add to low side (low and high side connectors are different sizes, so it only fits one fitting).
AC clutch should be engaging when adding freon, if not then no freon will flow.
Cause is most likely a leak in system, or faulty clutch.
It is best to get it serviced by a professional shop, evacuate system, and see if AC system will hold vacuum, if not the leak will have to be repaired before adding freon.
Saturday, August 29th, 2009 AT 9:10 AM
