1999 Pontiac Grand Am Water pump
1999 PONTIAC GRAND AM
REESER
1999 Pontiac Grand Am 4 cyl Front Wheel Drive Automatic
Where is the water pump located on my 1999 4cyl grand am? Is there anywhere on the internet to see a picture on how to change it?
May 29, 2008 at 6:59 PM
MNCMOPARS
  • 5 POSTS
[quote:37004082e7="Reeser"]1999 Pontiac Grand Am 4 cyl Front Wheel Drive Automatic
Where is the water pump located on my 1999 4cyl grand am? Is there anywhere on the internet to see a picture on how to change it?[/quote:37004082e7]
Hi. Follow your lower radiator hose, will take you right to it. Should be towards the front,pass. side. Will need to remove belt, not sure if bolt on pulley on that car, remove that, then water pump bolts, good to go! Be sure to use water pump gasket sealant! goodluck! Make sure your belting diagram is on the car also to re-install belt, if cant find it-draw a pic!
Jun 8, 2008 at 11:07 AM
