1999 Pontiac Grand Am vibration
105,000 MILES • 6 CYL • FWD • AUTOMATIC
TRISHROSE
When I come to a light or have to have brakes on the car vibrates and feels like it wants to "jump". But when driving it is fine
Feb 22, 2009 at 10:44 AM
MMPRINCE4000
  • 8,548 POSTS
Most likely the rotors are bad, possibly a caliper is not releasing.
Raise car, put on stands, with brake pedal released turn tires foward and see if you feel any significant resistance.
Remove the rotors and lay on flat surface, checking for warpage.
Also check suspension components, ball joints, tie rod ends, control arm bushings for excessive wear.
Feb 23, 2009 at 12:58 AM
