My coolant level Low and Tire pressure check lights keep coming on after having both switches replaced and reset.
Thursday, August 26th, 2010 AT 1:49 PM
LEGITIMATE007
MECHANIC
Have you erased the codes, usually they will shut off after a drive cycle. But its best to use a scan tool. If you havent erased them, have autozone do it for free. Or you can try unpugging the negative cable at night and in the morning and put it back on. Sometimes that works and sometimes it doesnt.
