My problem is the key is seized up and won't turn. The shifter is locked, but the steering wheel is not. I have removed the cover trim fro the radio which gives me some access to the ignition housing, and I have removed the two mounting screws - so the housing is loose, but everything is still hooked up and I cant pull it through the radio hole. Also, because the key won't turn, I am concerend I won't be able to remove the shifter cable due to it being locked in. I have a replacement housing in tact from a wreck parted out that appears perfect. It has a key that turns so I have the complete componet ready to install. My main question is how do I get the old housing out and release the shifter cable? Thanks in advance for your help!
Feb 6, 2010 at 6:21 PM
