1999 Pontiac Grand Am overheating
JUANSPONTIAC
  • 1999 PONTIAC GRAND AM
  • 6 CYL
  • 85,000 MILES
Hi, i've had problems with my car overheating for a while, i've replaced the hose that connects to the radiator, a new surge tank installed, a new waterpump and thermostat, i've had a radiator flush, I had to replace the intake manifold gaskets, but the problem is that I have to constantly put in antifreeze because the temperature gets hot and the warning light goes on and reaches temperature to about 280, pretty much the max, if you can help me I would so appriciate it, thank you
Saturday, October 31st, 2009 AT 1:29 PM
DOCFIXIT
  • 18,828 POSTS
Any white smoke out tailpipe on startup? Oil look normal?
Saturday, October 31st, 2009 AT 1:40 PM
JUANSPONTIAC
  • 6 POSTS
Theres white smoke in the morning, but not really at any other time when I start it, would that affect the cooling system, my oil is fine, just had it changed.
Saturday, October 31st, 2009 AT 3:36 PM
DOCFIXIT
  • 18,828 POSTS
There is coolant in combustion chamber if intakes good then headgasket only other possibility. You can have coolant tested for presence of CO if there then headgasket.
Monday, November 2nd, 2009 AT 3:47 PM
