1999 Pontiac Grand Am over heating and no hot air from herat
CHECKER
  • 1999 PONTIAC GRAND AM
Other Category problem
1999 Pontiac Grand Am V6 Four Wheel Drive Automatic 160000 miles
The engine over heats quickly and no hot air will come from the heater, and antifreeze over flows.
Sunday, December 2nd, 2007 AT 11:53 AM
Get the tests done below-
Have it block and pressure tested-do the block first to pinpoint a combustion leaking into the cooling system or a gas analyzer to sniff for hydrocarbons at the radiator fill neck.
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
If the block and pressure test passes check the following: Thermostat, Pressure test the Rad. Cap, Clogged radiator, Fan clutch, Radiator electrical fan, collaspe hoses, water pump.
Sunday, December 2nd, 2007 AT 1:10 PM
