1999 Pontiac Grand Am loud humming sound
1999 PONTIAC GRAND AM
119,000 MILES • 6 CYL • 2WD • AUTOMATIC
SHANNON88
I have a 99 grand am gt...new tires,new passenger side wheel bearing ( for speed sensor failure). now there is an loud like humming noise coming from the passenger side that was there before we changed the wheel bearing. the faster you go the louder the sound...Please Help!!!!!! I thought maybe the cv shaft...but I have no shaking just sounds like I have a bad tire.
Oct 15, 2008 at 6:45 AM
DOCFIXIT
  • 18,828 POSTS
When humming is going on slightly move steering wheel to left then to right any change. Let me know
Oct 15, 2008 at 6:59 AM
SHANNON88
I done that and to no avail....same noise...doesnt make a difference whether you turn left or right...still makes the same sound...I thought it was coming from the pass. side...wrong side..it is from the drivers side...could be the wheel bearing right? I jacked it up and the wheel doensnt move at all.
Oct 17, 2008 at 1:01 AM
DOCFIXIT
  • 18,828 POSTS
Place car on jackstands run in gear if noise is there not bearing. While up running can you pin point area of noise?
Oct 17, 2008 at 8:28 AM
