1999 Pontiac Grand Am Ignition switch
1999 PONTIAC GRAND AM
MARTHA J
Interior problem
1999 Pontiac Grand Am 6 cyl Automatic 165000 miles
Ignition switch will not turn. Should I remove the switch & how does it come out? I have taken out the radio & screws that hold the switch in place. However I am unable to disconnect the plug in electricial connections & the cable that is in the back of switch. What to do? Thank you!
May 5, 2010 at 10:48 AM
BLUELIGHTNIN6
  • 16,542 POSTS
check out our article on this common problem before trying to replace the switch.. http://www.2carpros.com/first_things/why_wont_my_ignition_switch_turn.htm
May 5, 2010 at 11:07 AM
