Removal & Installation
NOTE
You must use a scan tool to perform the BCM theft deterrent relearn procedure whenever you replace the ignition switch lock cylinder.
Disconnect negative battery cable.
Remove instrument panel (I/P) accessory trim plate.
Insert the key to the ignition lock cylinder.
Remove the ignition lock cylinder from the switch:
Using a small curved tool or an L-shaped hex wrench, depress and hold the detent on the ignition lock cylinder. If you cannot locate the detent with the tool, remove the radio. View the detent through the radio opening.
Turn the key to the ON/RUN position.
Pull the ignition lock cylinder out with the key.
Remove the key from the lock cylinder.
If the cylinder does not rotate or is seized, ignition switch will need replaced.
To install:
Insert the key and turn the lock cylinder to the ON/RUN position.
Install the lock cylinder to the ignition switch. If you turned the key slightly while removing the lock cylinder, you may have to align the white colored ignition switch rotor (1) with the lock cylinder (2). You can rotate the ignition switch rotor (1) with your finger.
Turn the key to the OFF position and remove the key.
If necessary, install the radio.
Install the I/P accessory trim plate.
Connect the negative battery cable.
If a new lock cylinder was installed, perform the BCM theft deterrent relearn procedure.
Jul 31, 2019 at 9:51 AM
