To remove the headlamps you will need to remove the plastic panel on top of the headlights after this is removed you will see two clips: one on each side of the headlamp housing pull the clips up to release the headlamp foward to access the bulbs in the back, be sure to lock these clips back down when the headlamps are put back into place. Also be sure headlight bulbs are sealed in place to prevent moisture from entering the openings. hope this helps
jon
Oct 14, 2008 at 7:06 PM
