1999 Pontiac Grand Am Fuel Pump?
LEFTTURN3N8
  • 1999 PONTIAC GRAND AM
  • 4 CYL
  • FWD
  • 180,000 MILES
As the car heats up there is a noise in the rear of the vehicle that gets louder the longer I drive it. I think it's the fuel pump. It sounds electronic. Does it sound like a fuel pump problem or do you have any other ideas? Thanks
Friday, April 2nd, 2010 AT 6:58 PM
MMPRINCE4000
  • 8,548 POSTS
If it was pump, then pull over, if noise is still there, then pump is possibility, if not then a rear suspension component.
To be sure, check fuel pressure with mechanical gauge.
Saturday, April 3rd, 2010 AT 8:36 AM
