1999 Pontiac Grand Am Fuel Pump
DON HIBNER
Me again, wondering how I have to access the fuel pump on the Grand Am. Doe s the tank have to be dropped? I tried pulling the rear seat and checking under the Insulation in the trunk and found no access points. I am fearing I have to drop the tank, which means I will have to take it to someone with a lift. Is this correct?
Dec 26, 2006 at 4:59 AM
SERVICE WRITER
  • 9,123 POSTS
Don,
Is this the one with the quad 4? Are you going after the fuel pump because of the miss? IF so, did you replace the coil housing and boots?
Tank has to come down for the pump if your'e still going down that path.
Dec 26, 2006 at 10:49 AM
