1999 Pontiac Grand Am Fuel filter
JUSTUS
  • 1999 PONTIAC GRAND AM
  • 6 CYL
  • FWD
  • 170,000 MILES
Our car stalled out on a 10,000 mountains pass and we were unable to get it started again and we waited 2+ hours. When we would try and start it, it would turn over but it sounded like it was not getting any gas. The gas tank is full. Any help, we need to get our car home.
Sunday, June 21st, 2009 AT 8:30 PM
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, cap and rotor /distributor pick-up coil, ignition control module, ECM, Ignitor cam and crank sensors- Note: If it doesn't apply disregard it
Sunday, June 21st, 2009 AT 8:36 PM
