1999 Pontiac Grand Am Extreemly Rich Starts
1999 PONTIAC GRAND AM
75,000 MILES • 4 CYL • FWD • AUTOMATIC
KIRSCHG
We very good gas mileage, 25 city 32 highway. It also is very responsive for a 4-cyl, just a touch of the accelerator and your off to the races. The Rich Start problem has been getting slightly worse each year for the past 5 years. When the engine is cold it will start by itself but you can smell rich exhaust if the windows are down. When Hot after being off for 10 minutes it will not start unless you slowly press down on the accelerator while cranking. Hot or Cold the idle immediately comes down to normal in 5 or less seconds. Recently the problem has been getting worse and now just as it starts there is a large cloud of blue smoke at the exhaust. Oil level does not show any usage yet.
Aug 31, 2009 at 11:07 AM
Probable causes could be the coolant temperature sensor , clogged return line and leaking fuel pressure regulator, for the blue smoke could be the valve seals-
Aug 31, 2009 at 11:56 AM
KIRSCHG
I disconnected the connecteor from the sensor that is mounted on the Thermostat housing, started and drove the car for a bit. There was no affect to the Rich start. But the transmission shifted very sharply on all Up shifts and the Service Engine Soon light came on after the 2nd Hot start. I reconnected the sensor connector and after the 3rd start the Service Engin Soon light went out.
Is there another Coolant Sensor?
If so Where?
Sep 1, 2009 at 10:30 AM
