1999 Pontiac Grand Am ENGINE COMPRESSION
SUSANELLO
Engine Mechanical problem
1999 Pontiac Grand Am 4 cyl Front Wheel Drive Automatic
the timing chain assembly was replaced and now the #1 piston has no compression. the problem started out with the engine going dead, after investigating the problem, we found out that the timing chain housing was broken, now the whole assembly has been replaced and there is no compression on the #1 piston. what do i do next?
Feb 21, 2009 at 4:53 AM
  • 110,248 POSTS
Hi:
If you are 100% sure the engine has been timed correctly, I would check for a bent valve that is stuck open or a hole on the top of the piston. Those two things are the only things that I can think of that would cause 0 compression.
Let me know what you find.
Feb 25, 2009 at 2:39 AM
