1999 Pontiac Grand Am door won't shut
1999 PONTIAC GRAND AM
RFABB123
I have a 1999 grand am 4 door, the passenger back door will not close.My friend got out of the car when shutting the door, it will not close now
Oct 16, 2009 at 9:05 AM
MMPRINCE4000
  • 8,548 POSTS
Check the striker bolt on door jamb, it may be loose or worn.
Sometimes the lock in door will get stuck, you can use a lube and screwdriver to fix, use other door as an example.
Oct 17, 2009 at 1:33 AM
