1999 Pontiac Grand Am Creeking
1999 PONTIAC GRAND AM
113,000 MILES • 6 CYL • 2WD • AUTOMATIC
KNITTER
I have an annoying creeking sound when I turn coming from the steering column. What is this from or how do we fix? Is it a signal of something larger?
Oct 22, 2009 at 4:16 AM
MMPRINCE4000
  • 8,548 POSTS
Start by checking the front end steering/suspension components:
Raise car, put on stands. Grasp tire and push/pull both horizontally and vertically, if any movement then possible wheel bearing, ball joint, tie rod, control arm bushing.
Check CV boots for any signs of leakage or cuts/rips in rubber boot.
If everything is OK, then the steering column will have to be removed and inspected.
Oct 24, 2009 at 3:47 AM
