I have a 99 Pontiac Grand Am with a 3.4 in it. The car will run for about 45 minutes to an hour and will just shut off. It now seems to act like it is out of gas. You can start it back up and it will run for about 10 seconds and do the same thing again. It is not out of fuel, I have replaced the fuel pump, plugs, mass air flow sensor, map sensor, crank sensor. I am to the conclusion that it may be in the coil pack area or the bcm but would like other opinions or options. Thanks
Sep 24, 2010 at 9:27 AM
