Make sure the cooling fans are working. If not, the the fan motor is bad, fan relay, or fan switch.
You can check the fans by disconnecting the connector and apply 12V to the fan motor, if they run then the relay, or switch.
SPONSORED LINKS
Friday, September 12th, 2008 AT 5:38 AM
