1999 Pontiac Grand Am Bangs when shifting from park to driv
1999 PONTIAC GRAND AM
126,000 MILES • 6 CYL • FWD • AUTOMATIC
MGPULLI
Car makes a banging noise when shifting from park to drive or reverse, less obvious noise when changing gears while moving. Transmission does not slip between gears. Do you think this would be a transmission issue or motor mounts?
Dec 4, 2009 at 12:54 PM
MMPRINCE4000
  • 8,548 POSTS
I would suspect the motor mounts if the banging noise is the only symptom you have.
Dec 4, 2009 at 11:24 PM
