Please help me! My car was running fine besides the gas fumes I could smell every once in a while.. and then as I am driving, the whole car just shut down. Changed the fuel pressure regulator because it looked like it was leaking, that did not fix it. Told husband to change fuel filter but he said that it was getting alot of fuel to where the regulator goes on "there shouldn't be anything wrong with it"??? Car will attempt to start and when you gas it, it sounds like it has a bad cough and only last about 3-4 seconds or exhaust leak, Lol. Sorry It is hard to explain. I hooked it up to scanner and it says PASS No Codes everything checked ok. I am trying to figure it out before he gets home :) Do not want to put it in shop
Feb 4, 2009 at 5:23 AM
