1998 Pontiac Grand Am Water Pump?
JONDA99
  • 1998 PONTIAC GRAND AM
  • 4 CYL
  • FWD
  • 99,500 MILES
Regarding Post by marknutter on SEPT 12, 2007 talking about coolant leak on drivers side coming out exhaust manifold gasket. The response was water pump, but the water pump is on the passenger side. Could this still cause this? It would save me a ton of diagnostic time if that was the case. Thank you.
Friday, December 5th, 2008 AT 10:48 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation.
If it is leaking from the manifold then it is probably not a water pump issue.
I suggest having the block dye tested for cracks. You may need to pull the cylinder head to inspect for cracks as well, along with checking head gasket and exhaust manifold gasket.
Friday, December 5th, 2008 AT 11:43 AM
