1998 Pontiac Grand Am Transmission failure
U00DRK1
  • 1998 PONTIAC GRAND AM
  • 6 CYL
  • FWD
  • 120,000 MILES
I have a 98 Pontiac Grand Am with about 120,000 miles on it. I was driving down the road today at about 50 MPH and the trans just started slipping. It was like someone just threw it in neutral. I coasted to a parking lot and it would not move. I checked the cable where it attaches to the trans bracket and it is moving fine as we shift through the gears. It just doesn't do anything. I checked the fluid and it is fine. It just seems like it is in Neutral and will not move. I would hate to pull the trans if it could be something easier like a switch or something.
Sunday, August 8th, 2010 AT 10:39 PM
  • 109,913 POSTS
Did any warning lights come on?
Monday, August 9th, 2010 AT 12:28 AM
U00DRK1
No warning lights at all. Just acts like it is in neutral through the whole shift range.
Monday, August 9th, 2010 AT 11:19 AM
  • 109,913 POSTS
The only thing I can recommend is to make sure the ATF is full. If it is, you need to have the trans control module checked (TCM). If it is good, the trans needs to come out.
Tuesday, August 10th, 2010 AT 12:44 AM
