Welcome to the forum, I'd make sure the battery has a full charge and connections are good. Also check the charging system. When the problem occurs, turn the key to crank, watch the lites, any lites, see if the lites react, when trying to crank. If no reaction from lites, they should blink--go out-- something, if no reaction, check for open circuit to the starter. Some of the national brand autostores will check the starter for free. Yeah, you have to take it off and take it to them. With the starter off, sometimes, I lay it on the ground, hook jumper cables up to it, just to see if the gear will kick out and the starter spins. That is no a load test, not conclusive.
SPONSORED LINKS
Thursday, December 10th, 2009 AT 10:41 AM
