1998 Pontiac Grand Am stariing proplem
230,965 MILES • 6 CYL • 2WD • AUTOMATIC
WIJAY
when my car get heat as mean normal temp after that stop start engine crank very slow i changed new battery starter motor still same proplem i change new ecm too but same proplem pls give some idea
Jan 28, 2009 at 8:32 AM
JDL
  • 16,098 POSTS
Are you saying the cranking rpms are good when the vehicle is cold and slow with the vehicle hot?
Are all the battery cables/wires clean and tight on both ends? You may need to do a voltage drop test on the battery cables, cold and hot.
There may be an engine mechanical condition, making the engine hard to turn when hot? Can you tell a difference in the amp draw?
Jan 28, 2009 at 10:54 PM
