1998 Pontiac Grand Am stariing proplem
WIJAY
  • 1998 PONTIAC GRAND AM
  • 6 CYL
  • 230,965 MILES
When my car get heat as mean normal temp after that stop start engine crank very slow I changed new battery starter motor still same proplem I change new ecm too but same proplem pls give some idea
Wednesday, January 28th, 2009 AT 4:32 PM
JDL
  • 16,098 POSTS
Are you saying the cranking rpms are good when the vehicle is cold and slow with the vehicle hot?
Are all the battery cables/wires clean and tight on both ends? You may need to do a voltage drop test on the battery cables, cold and hot.
There may be an engine mechanical condition, making the engine hard to turn when hot? Can you tell a difference in the amp draw?
Thursday, January 29th, 2009 AT 6:54 AM
