1998 Pontiac Grand Am Domeand Floor Lights
1998 PONTIAC GRAND AM
80,000 MILES • 4 CYL • 2WD • AUTOMATIC
TRA21DUKE
My dome and floor lights stay on for 20 mins whenever they turn on. Is there anyway to fix this? Will it pass a Maryland inspection like this?
Aug 14, 2009 at 1:38 PM
DOCFIXIT
  • 18,828 POSTS
Hi
Problem is timer circuit in Multifunction Module located in convenience center underdash left of collumn. No repair dealer item. Are all floor bulbe lighting up? Ask cause if a couple are out time is load sentive and will stay on longer. Noy sure about Maryland inspection but would see no reason to fail for coursety light snafu.
Hope this helps
Thanks for donate
Aug 15, 2009 at 3:52 AM
TRA21DUKE
Thanks for the quick reply. The floor lights are on. Is it something that can be fixed?
Aug 15, 2009 at 6:22 AM
DOCFIXIT
  • 18,828 POSTS
Replace timer -alarm module
Aug 15, 2009 at 8:05 AM
