1998 Pontiac Grand Am BATTERY IS BEING DRAINED
160,000 MILES • 6 CYL • 2WD • AUTOMATIC
SHERRY5366
My son has a 1998 Pontiac Grand Am and recently he has been having to press the gas when starting up his vehicle and then finally it wouldn't start at all. Well, he had a new battery put in it and it started fine the 1st time but the 2nd time it wouldn't start at all. Could this be the alternator?
Jul 30, 2008 at 5:41 AM
CALYPSO93
  • 43 POSTS
usually when there is a problem with the alternator, a battery light will come on on the dash. If the car has an ammeter, or battery gauge, it will show low or in the red if there is a problem with charging. I would test voltage on the battery when the car is running, should be 14 volts +/-. It sounds like it could be a fuel problem, perhaps the pump is failing.
Jul 30, 2008 at 2:29 PM
SHERRY5366
You might be right, I went home yesterday to try and start it and everything is coming on in the car but it won't start. Let me ask you this, when I went to start the car there is just a long noise and it is not even trying to turn over. Could this be the starter or are you still leaning towards a fuel problem?
Jul 31, 2008 at 12:44 AM
CALYPSO93
  • 43 POSTS
when you turn the key to the on position, you should here the fuel pump humming in the tank. Get someone to listen at the back of the car for it. Also, check to make sure that the battery, starter, and motor grounds are good, and not corroded.
Jul 31, 2008 at 12:24 PM
