1998 Pontiac Grand Am Air in the coolant system
185,000 MILES • 6 CYL • FWD • AUTOMATIC
SNOWDAWG
Replaced the radiator, water pump, thermostat, and heater core and when i try to bleed the air out it seems to keep getting more air in it. When i try to drive it the temp will start to go up while cold air is coming out of the vents but then it will start to drop and i will have hot air from my heater again for just a minute then its cold again. Will the intake manifold gasket or head gasket cause this .
Jan 19, 2008 at 9:47 AM
MASTERTECHTIM
  • 4,750 POSTS
not intake gasket. head gasket, yes.
Jan 19, 2008 at 9:53 AM
