1998 Pontiac Grand Am
MTCDAD
  • 1998 PONTIAC GRAND AM
Engine Performance problem
1998 Pontiac Grand Am Two Wheel Drive Automatic 125000 miles
Had the fuel pump in the gas tank replaced. The person that did it said that it still will not start because the anti-theft device is shutting the fuel pump off when it tries to start. Is there a way to reset the anti-theft device so we can start the car?
Sunday, June 28th, 2009 AT 9:56 AM
JDL
  • 16,098 POSTS
Hello, the theft system disables the injectors not the fuel pump, I believe. After trying to start, if the theft lite is flashing, leave the key on, wait for the lite to stop flashing, it may take about 10 minutes. If it stops flashing, turn the key off, then try to start. Maybe a problem with the passlock sensor? Any codes?
Sunday, June 28th, 2009 AT 3:14 PM
