1997 Pontiac Grand Am shaking in front in end
1997 PONTIAC GRAND AM
139,000 MILES • 6 CYL • FWD • AUTOMATIC
QDC
i hear a knock when ever i go over a bump on the drivers side. the steering wheel vibrates at time when i hit over 40 mph. what could be the problem?
Oct 10, 2009 at 6:44 PM
MMPRINCE4000
  • 8,548 POSTS
Start here:
Raise car, put on stands. Grasp tire and push/pull both horizontally and vertically, if any movement then possible wheel bearing, ball joint, tie rod, control arm bushing.
Check CV boots for any signs of leakage or cuts/rips in rubber boot.
Oct 11, 2009 at 8:26 AM
